Results 1 to 8 of 8
    Aug 2018
    Question Peugeot 306 Gti Marelli IAW1AP.10 immo off
    Hello guys,
    There is a car with Magnetti IAW 1AP.10 ECU
    ECU nr.: 16264.064 / 9632029580
    Car: 1999 Peugeot 306 Gti 2.0 16v petrol
    I would like to do immo off.
    I found some clock file for 28f512 with immo decoder.
    I have blank AM28F512 and GQ4X4 programmer.
    I'm afraid of a little because it isn't the classis soic8 soldering job like VAG EDC15.
    Is somebody has a proper working tested solution?
    I would ve very grateful if get some help
    Thanks in advance
    Le-Mans's Avatar
    Jun 2017
    Here all info for off
  3. The Following 3 Users Say Thank You to Le-Mans For This Useful Post:
    serekana (27th June, 2023), user202 (29th January, 2021), Xixi61 (9th February, 2021)
    May 2020
    france
    Hello
    I have one to do I have a gq4x is fgtech
    do you have the exact procedure thank you
    Le-Mans's Avatar
    Jun 2017
    if you have gq4x with plcc32 adapter is possible to make off
  6. The Following User Says Thank You to Le-Mans For This Useful Post:
    Xixi61 (8th February, 2021)
    May 2020
    france
    thank you for the answer I have his
    but I don't have the procedure
    I read immo on tms or on 32f but nothing conclusive
  8. #6
    May 2020
    france
    28f as much for me
    if you have the procedure i want to thank you
  9. #7
    Aug 2018
    I have a PLCC32 adapter 2 different type use them many time for VAG MSA ECU-s hope that for 306 gti Marelli the clock file will be worked in this weekend .
  10. #8
    Apr 2023
    Hi. I need Password please.
    Quote Originally Posted by Le-Mans View Post
