Originally Posted by
GlennGlenn
nico2786
The data from the first readings the previous post are read first time without error and without any wasted ISRcnt, please see the IDE taken from the ISRcnt data.
11111 0000 1010 1000 0111 0000 1110 0001 0010
AES Hitager version 1.0.1.26848
arduino version 2
Sending: o
adapt target:1A adapt samplingT:B6 adapt readval:FF RFON
Sending: i05C0
transfer
ISRcnt:3D
1______1_____1_____1_____ 1__0_____0_____ 0_____0_ _1__0__1__0__1__ 0_____0_____0____
38, 25, 38, 27, 36, 27, 36, 27, 42, 57, 32, 31, 34, 29, 32, 39, 64, 63, 64, 63, 66, 59, 32, 33, 30, 33, 30,
_0__1_____1_____1__0_____0______0_____0__1_____1__ ____1__0_____0_____0______0__1__0_
37, 60, 31, 32, 31, 40, 59, 34, 29, 32, 33, 30, 39, 58, 33, 32, 31, 40, 59, 32, 29, 32, 31, 30, 39, 64, 61,
____0__1__0_____STOP
30, 37, 66, 57, 40, 241, 0,
RESP:0A870E12
EOF
The second set of data from the newer software is correct up to 321 (stop) but carries on collecting nonesense interrupts.
The 2 tests were done using same tag in fixed position, same iprog reader, same arduino, only arduino ino was changed and original/ newest AES Hitager versions.
Everything the same, but the adapt_samplingT values are very different, someone has changed the samplingT program, why?.
This may be causing your error.
