Hi everyone last time I do it stage 2 for audi a3 1.8T can somoene check if its good made, beacuse customer complaine the car is not sow powerfull what he ecspect, in car is installed hybride turbo. Thanks in advance
please post org file + tuned so i can check
regards
BMW S1000RR (28th January, 2021)
okey will check
BMW S1000RR (29th January, 2021)
and the finall version from last tuner, can somoeone check if its good ?
None of the three are good, the last and the best also has the lambda deactivated but many maps have not been touched.
File service, Custom Remapping, stage 1 & 2 dyno tested.
Petrol + Diesel
Adblue dpf egr Only tested working solutions.
Use thanks and Rep if my help was helpfull.
Somoene can help finish this stage 2 right, please I paid for 3 files and no one is do it right.
Anyone Please ?
So best would be if you safe the 3x ~50€ database shit money , multiply by 3 or 4 and get local tuner done the job right.
maicsonecutune (30th January, 2021)
Thanks a lot that whrily helps me 🤣 I dont understand, beacause this forum is for help, and I asked couple times and I get only how bad files are what I posted, do it bij guys also from here 🤔 All of You also was beginners and wont to learn, I also wont but how I can do it from bad stages. I see a lot guys just post files for make stage, dtc off and they get just for free. I post files for check and correct and nobody wont to help👍
See you contribute for forum and compare.
I will do if I can help. I am whrily confused beacuse last file is made buy official uk tuning garage Files@riverisde-team.co.uk, can some of You master of files can say what is bad or not finish in file ?
bro, why you stick on a company that not even can tune ME7.5 ecu ..search for other tuner. best you can do
whats shit in your file first lambda to fat to much ign for this boost you requested 1,5 bar than some maps forget . nobody know what your turbo can handle , what wastegate is on it 95 % on hybrid is shit an make no power . than u drive original injectors :-D to small 220-230 is absolute end when your fuelpump 100% work fine !
best spend money search a good tuner he know what he do and buy a file make 2-3 times log send him and he fixed it with bigger injectors and maf housing
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
AVDigitale (31st January, 2021)
