Results 1 to 5 of 5
    mainhattanracin's Avatar
    Oct 2020
    Kosovo/Albania
    Default Range Rover Sport V8 SC | DTC P0171 OFF !! NEED HELP Denso MB 279700
    Hei Guys i have some problems with my range rover i change o2 sensor fuel pump katalystic every think but i have permanent this DTC.
    The Workshop says everything is okei i change Air intake ans sensor i lose more thank 6k €
    Please set it off
    DTC P0171 / P0430 / P0420
    SET IT OFF THANKS GUYS Denso MB 279700
    Babos's Avatar
    Mar 2012
    Here your mod file.
    May 2020
    tot557545@gmail.com
    Hi everyone I can make and extract these DTC error codes from this ECU,solution Worked
    rep+thnx button press
  4. The Following User Says Thank You to ecuprogramer For This Useful Post:
    mainhattanracin (31st January, 2021)
    Oct 2020
    Kosovo/Albania
    Need Pass and can you set off P0174?
    May 2020
    tot557545@gmail.com
    hi sent you rar pass , DTC P0171 / P0430 / P0420 off test and report to forum
