Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    Supas's Avatar
    Jun 2020
    I don't remember which capsule brings the micro ... but I would change the micro directly if it is not possible to read the incircuit the uch ... in case of desoldering it uses flux and hot air only to the legs ... never to the core of the micro
  2. #17
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by eric paris View Post
    hello
    you may have a label in the remote control with a code, with the trantir software you can find the pin code
    if you see above i have the pin code from the key, BUT i have other uch.... is pin code from key enough to programming remote in donor uch?
  3. #18
    Quote Originally Posted by Panathaole View Post
    any pin out to read the uch? S103600301 A otherwise i exchange the mcu's....(it is sensitive in heat???)
    Yes, you can swap mcu. But I agree with Rafal, the best solution is to install an aftermarket remote - you will have 2 keyfobs, instead of old ir ori which can stop working very soon, or receiver can die ....
  4. #19
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    yes, i understand that for aftermarket remote, but car came with two working keys.........
  5. #20
    if your uch is new l think you can
  6. #21
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    It is used one that is working right, i don't make it virgin because i have only renolink 1.87(ori)
    And it doesn't support that old car....
  7. #22
    can you try this , sorry l have it only in french
  8. #23
    document from dialogys
    in the pdf you can select the text and translate it into your language it's easier
  9. #24
    Aug 2015
    Ok so much missinformation here.
    Pin code sync procedure will work only if your keys came with replacement (as you call it NEW) uch.
    If not, as someone said before, you can try to swap MCU from OLD unit to replacement (NEW) and then try pin code sync procedure.
    Your other option is to PROGRAM old keys to "NEW" uch. You can do it by using carprog, link for all info here - https://www.car-auto-repair.com/carp...megane-scenic/
  10. The Following User Says Thank You to dtip For This Useful Post:
    rafal (31st January, 2021)
  11. #25
    rafal's Avatar
    UK - PL
    yes it is correct...................and it reason as i wrote before why the best will be mount aftermarket module with remotes
    but................if user want to play few houres with old crap car - no problem
    need help
    now my goal is to buy xp-005
    who will help?
  12. The Following User Says Thank You to rafal For This Useful Post:
    dtip (31st January, 2021)
  13. #26
    Aug 2015
    Quote Originally Posted by rafal View Post
    Agree, most users that posted on this thread are confused and are not aware that SYNC procedure is not procedure that can add new (used) key to the uch that is not matched to
  14. #27
    Ecuprog31's Avatar
    Mar 2018
    Hello you need to virginise uch and then you can add used remote if your ecu is in immo off state no problem
    if you have Renault ecu tool it’s easy by obd
  15. #28
    dijo's Avatar
    Swap MCU or clone MCU is your only/best chance, and you can reactivate immo to on...
  16. #29
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Hi again, i manage to find a remote from the "new" uch, the remote works fine, i extract the code and make a second key from the old bsi with carprog...
    Immo in dash disappear now,
    I put the second key i enter the code, i push the central lock button and i push key button too, i hear the locks once but remote is still unprogrammed, i don't have immo light on dash, and i cant programming the second remote with everything combination i found
  17. #30
    hello,
    the pdf file don't help you ?
