Results 1 to 15 of 15
    Jul 2015
    UK
    Default CEM-L & CEM-H Synchronization utility for VOLVO needed
    Looking for this soft as codecard discontinue it for some reason..... Working at my Volvo XC90, been mislead by one of big Volvo specialist in Europe for three months and dump in the end so decided to syncro immo for myself. Have the older version of this tool, but is not for L or H cem
    Jul 2015
    If synhronization is losted by battery discharging , this sw will not helps you.
    MartiLer's Avatar
    Dec 2016
    can be done by hand.
    Jul 2015
    UK
    Absolutely, but need knowledge, otherwise wont work.
    soxten's Avatar
    Mar 2013
    Need help!
    Looks like Codecard has take away small prog for Volvo sync Cem-L to ECU.
    Do we have other program that kcan make this sync?
    In 2017 I did make a picture of how info is stored in CEM-L when I did help Pauliuz at codecard.
    see attached picture.
    Now I need help to sync immo on CEM-L to Denso ECU.
    Any as now or can help me with info?
  6. The Following 4 Users Say Thank You to soxten For This Useful Post:
    dziongas (7th June, 2024), hmagga (24th March, 2024), xseva (17th January, 2025), Yhoni (26th April, 2025)
    MartiLer's Avatar
    Dec 2016
    ECM Denso 93A86?
    Apr 2016
    has anyone had any luck at cloning a CEM H from a 2007 Volvo XC90? i can move the eeprom but the car will not start still. from what i understand is the flash needs to be copied as well. any help would be greatly appreciate
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by birchbark506 View Post
    "all" things you want to clone from a volvo you need to copy flash also, volvo uses sync data in all of them
  10. #9
    KriptoKey's Avatar
    Feb 2012
    indeed friend. eeprom and flash are married.
    if you want to clone you have to write eeprom and flash
  11. #10
    Apr 2016
    I already moved the eeprom chip to donor CEM H, now I need to find away to read the flash chip, I tried most of the wiring online with vvdi prog but unable to connect to chip
  12. #11
    achaccha's Avatar
    Nov 2010
    You can use Multiprog to do flash reading.
    But I would like to know if there is any tool that can synchronize CEM H with eeprom ECU 95080 0261S04511 1039S26974 LC.2.
    If anyone can provide please contact.
    thank you
  13. #12
    Apr 2016
    Quote Originally Posted by achaccha View Post
    thank you
    you mean smok?
  14. #13
    soxten's Avatar
    Mar 2013
    You only need to have Eeprom from both CEM-L and ECU.
    (Eeprom and flash on CEM-L has crypto that is why you take CEM eeprom sync and write to ECU eeprom and it work)
    Need help to sync, see attached files.
    CEM Eeprom is 93C86x8
    ECU Eeprom is 95P08
  15. The Following User Says Thank You to soxten For This Useful Post:
    sntfrancisco (20th June, 2023)
  16. #14
    soxten's Avatar
    Mar 2013
    Here is the program that Codecard did make, but looks like server is down.
    Any as can make program like this or have connections to talk to Codecard?
  17. #15
    MartiLer's Avatar
    Dec 2016
    sync data and keys are damaged from the drawdown of the battery. mileage 389157 km. Read the Id meg48 from the original keys for this car.
    I made this program for myself.
  18. The Following 2 Users Say Thank You to MartiLer For This Useful Post:
    dziongas (7th June, 2024), richard27 (28th March, 2024)
