Results 1 to 4 of 4
    sdnatlst's Avatar
    Aug 2011
    England
    Default corsa D 1.3 Z13DTH ecu replaced with Z13DTJ ecu P0090-06 after program
    hi all i replaced above ECU and coded with OPCOM MJD603
    now car cranks but no start with fault code P0090-06 fuel pressure regulator short to ground
    i think becasue i swapped with z13dtj this car thinks it has a sensor it actually doesnt
    does anyone know the fix? does anyone have Z13DTH full backup i can write?
    if i write just MPC and FLASH but leave EEPROM programmed as it is now, will it then start the car?
    Tools owned -
    AD100 PRO, Lonsdor, FVDI 18, FVDI 20, VVDI PROG, VVDI2, VVDI MB
    CGDI BMW, SuperVag, Renault ECU tool, OBDstar X300 DP Plus, AUTEL im508
    VVDI Mini Keytool, KeyDIY KDX2, SBB, ACDP CAS/KVM
    Opcom, VCDS pro, Diagbox, Multiecuscan, Forscan, JLR SDD
    Oct 2018
    Default Hi
    Here you have a DTH pm pass
  3. The Following 2 Users Say Thank You to macmateusz For This Useful Post:
    sdnatlst (1st February, 2021), vladar1 (19th May, 2021)
    Aug 2008
    you could just bdm the old ecu you have then copy everything to the new ecu
    you dont need the eprom file from the bdm dump above, you need your eprom dump from your cars ecu
    because this holds the cars immo etc
  5. The Following User Says Thank You to tango For This Useful Post:
    sdnatlst (2nd February, 2021)
  6. #4
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Post both ecus info, or upload ecus label...
