02 AUDI TT CLUSTER PROBLEM
Results 1 to 8 of 8
    Top Poster wiggyshome's Avatar
    UK, ESSEX
    Default 02 AUDI TT CLUSTER PROBLEM
    Hi all
    can anyone help me please
    i have a 02 Audi TT need to read imm0 code and change miles, i have tryed vag commander and vag eeprom reader but they wont read this cluster , i have tested software in another Audi a6 reads all ok its just this tt it wont read
    can anyone help
    wiggyshome
    Member lucianica's Avatar
    Bucharest/Romania
    you try with original vag can commander ?
    if yes try to read as "direct"
    if no,maybee you use clone of vag commander
    best job you can make on desk
    remove dash,read 912dg128............is easy
    post dump here..........and you will find what do you need
    best regards
    UK, ESSEX
    Quote Originally Posted by lucianica View Post
    best regards
    i have the clone Vag commander
    so i take it wont work in the car
    so i have put the dash on the bench and here is the file
    thank you
    wiggyshome
  4. The Following User Says Thank You to wiggyshome For This Useful Post:
    jlbodi (12th October, 2022)
    Bucharest/Romania
    hello
    eeprom area is good readed,but your file have 64Kb
    i think should be 2Mb,eeprom and flash content
    anyway,to the subject
    you have 160862km or 118280 miles
    tell me what value do you need
    regards
    Bucharest/Romania
    dash without cks
    only eeprom area
    try
    Hi i am in the same situation, customer has used vag tacho (unsure of version) and display reads 999999.. i have tried reading the 912 with tacho universal (Audi 2000 cable) - it seemed to save a file on the tacho universal (ept file) but read VERY quickly so not sure if dump is good or not.. I will try and upload to computer asap.. if read is not good, is there anything else i can use.. i have Xprog M, willem and tachopro on hand and if need be will have to order something to read/write 912 in circuit.. any suggestions..
    Also does anyone have a good dump for 2002 TT (Jaeger clocks) 9N2 920 980 A (id'd as a M73 with tachoPro)
    Cheers Guys
    carsoftobd's Avatar
    Feb 2011
    Hello
    Very easy with moto programmer only 4 wires
    carsoftobd's Avatar
    Feb 2011
    With TU if dash have checksum don't try audi cable 2000 go to audi menu and audi MM diag, Tested 100%
