Results 1 to 5 of 5
    Jul 2019
    FINLAND
    Default IPHONE 8 Plus, low ear speaker sound!
    New speaker,
    still quiet
    how more volume?
    ideas where the fault is?
    still quiet
    Sep 2020
    USA
    Perhaps the problem is with the quality of the ear speakers themselves. Which ones did you buy yourself? Tell me more details, then it will be easier to give an answer and advise something.
    Nov 2015
    Bulgaria, Razgrad/Varna
    Hey, it's not the speaker it is the metal protective grill that is glued to the LCD (the one that you can see form the outside of the phone). since it's you first try, remove the speaker and wipe some alcohol on the front side of the grill, then use pressurized air to blow from the outside (be careful you have to remove the flex cable not only the speaker or you will damage the mic.)
    Prichyndel's Avatar
    May 2012
    UK
    Replace/clean the metal mesh or poke a hole in it.
    toyota123's Avatar
    Sep 2019
    remove screen and perform cleaning process , use video guide..
