Samsung SM5 BCM pincode help
Results 1 to 1 of 1
    Nov 2018
    Default Samsung SM5 BCM pincode help
    Hello all!
    The following vehicle arrived at the workshop:
    Samsung SM5 2006 AT SR20de 2.0.
    The vehicle was taken to change the engine oil and automatic transmission.
    After changing the transmission oil, the vehicle did not start again, the remote control does not work.
    When scanning with Launch x431, it detects a Can error in the BCM.
    Check resistance on CAN Bus and it is 60 ohm.
    Disconnecting the BCM allows the vehicle to start.
    Therefore I think the error is in the BCM so I took out the eeprom and read it with UPA.
    Does anyone know what the pincode is?
    I enclose the DUMP.
    Thank you very much, I hope to solve the problem.
