Results 1 to 5 of 5
    jacekripper's Avatar
    Feb 2016
    EU
    Default 19.2V NIMH battery rebiuld with 18650?
    Hi all.
    I have 14 years old impact gun Ingersoll Rand - absolutely brilliant and powerfull - and batteries are dead obviosuly. Seen some YT videos and decided go for it. I have many 18650 batteries kicking around and easiest way would be connect 5 in series, 5S BMS on top - job done... But! Can I put in another slot of 5 in series, (plenty space inside housing) another 5S BMS on top and connect both units paralel? Is it good idea, or is out there somwhere better way?
    Aug 2020
    Yeah you can do that no problem, same voltage more amp hours
    HaynesPro online + 2022.02a version available, message for where to get it!
  3. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    jacekripper (7th February, 2021)
    Feb 2016
    EU
    Work in progress..
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by jacekripper View Post
    Work in progress..
    Did you finish the work?
    Mar 2022
    Netherlands
    I like these projects
    I did rebuild a lot of older machines and replaced them with the newer 18650 battery type.
    I use the battery's of dead laptop battery's and test the capacity and re-use them into other equipment.
    This is a cheap way to bring new life to older equipment.
