Results 1 to 15 of 15
    Dec 2020
    Default I am new in Techstream program
    Hi all
    I have Techstream 15.00.026 with the serial number already worked.
    AS well as I have MINI-VCI J2534 Chinese cable.
    What should I do? Tried to connect it to my LEXUS Lx570 but doesnt ?
    Thanks in advance
    Apr 2020
    Toronto, Canada
    Hi, did you install the Drivers for Mini-Vci cable?
    And after that , when you launch Techstream , From the top menu ,Go to the Setup .
    Choose Vim Select, Then next to Interface setup, from the drop menu, you should see.
    Xhorse- MVCI.
    Choose it, and select Ok at the bottom of that window.
    Hope this helps.
    Please dont forget to pess Thanks + Reputation.
  3. The Following User Says Thank You to Hondasilver For This Useful Post:
    alhusinawi (8th February, 2021)
    Dec 2020
    no I did not install the Drivers for Mini-Vci cable!! Could you please give it to me?
    MY computer is Windows 10 64bit and Techstream is 15.00.026
    Apr 2020
    Toronto, Canada
    Here is the Driver and a Installation message that was sent to when I purchased mine.
    There is a link for the video on how to do it.
    Dec 2020
    It is working well. Thanks
    Reputation already done
    Dec 2020
    My other question is: can use Techsream to check another kind of cars, for example FORD or Nissan or Jeely?
  8. The Following User Says Thank You to alhusinawi For This Useful Post:
    Hondasilver (8th February, 2021)
  9. #7
    Aug 2020
    Quote Originally Posted by alhusinawi View Post
    No you cannot.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  10. The Following User Says Thank You to crouchinggerbil For This Useful Post:
  11. #8
    Apr 2020
    Toronto, Canada
    I am glad it work out for you.
    It can only do Toyota, Lexus & maybe Scion since its Toyota.
    Your welcome.
  12. #9
    Dec 2020
    what can I do more than checking the car? I meant Techsteam program what can I use it for?
  13. #10
    Apr 2020
    Toronto, Canada
    It can do all the systems as far as i know.
    Like, ABS, SRS, BLIND SPOT, etc.
    There is a menu the shows you the system you can access to.
  14. #11
    Dec 2020
    Do you know if the website has a link to learn anyone on Techstream?
  15. #12
    Aug 2020
    The search function & youtube are your friends
  16. #13
    Dec 2020
    Thanks all
  17. #14
    Dec 2020
    Thanks a lot
  18. #15
    Dec 2020
    thnks a lot
