Hi all
I have Techstream 15.00.026 with the serial number already worked.
AS well as I have MINI-VCI J2534 Chinese cable.
What should I do? Tried to connect it to my LEXUS Lx570 but doesnt ?
Thanks in advance
Hi all
Thanks in advance
Hi, did you install the Drivers for Mini-Vci cable?
And after that , when you launch Techstream , From the top menu ,Go to the Setup .
Choose Vim Select, Then next to Interface setup, from the drop menu, you should see.
Xhorse- MVCI.
Choose it, and select Ok at the bottom of that window.
Hope this helps.
Please dont forget to pess Thanks + Reputation.
alhusinawi (8th February, 2021)
no I did not install the Drivers for Mini-Vci cable!! Could you please give it to me?
MY computer is Windows 10 64bit and Techstream is 15.00.026
Regards
Here is the Driver and a Installation message that was sent to when I purchased mine.
There is a link for the video on how to do it.
It is working well. Thanks
Reputation already done
My other question is: can use Techsream to check another kind of cars, for example FORD or Nissan or Jeely?
Hondasilver (8th February, 2021)
I am glad it work out for you.
It can only do Toyota, Lexus & maybe Scion since its Toyota.
Your welcome.
what can I do more than checking the car? I meant Techsteam program what can I use it for?
It can do all the systems as far as i know.
Like, ABS, SRS, BLIND SPOT, etc.
There is a menu the shows you the system you can access to.
Do you know if the website has a link to learn anyone on Techstream?
Thanks all
Thanks a lot
thnks a lot
