Results 1 to 8 of 8
    Oct 2015
    BRAZIL
    Default Wich Version of ODIS is currently running on Windows 10 under vas5054a?
    Please Guys,
    I have a vas5054a clone, it was running good Odis 3.0.3, but now it says needed to be updated. My system is Windows10 64 bits.
    I tried to install Odis 5.1.6, but it´s no longer supports vas5054a hardware.
    I heard about a patch that could make it work.
    I also heard about odis 4.3.3 its ableto run vas5054a.
    Please, wich version of ODIS can i use under windows10 64bits?
    Aug 2020
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  3. The Following 2 Users Say Thank You to crouchinggerbil For This Useful Post:
    jfim88 (29th October, 2023), rafaelhcesar (8th February, 2021)
    Oct 2015
    BRAZIL
    Please,
    Sent you private message for password, same for "Thanks".
  5. The Following User Says Thank You to rafaelhcesar For This Useful Post:
    ltmpsd (21st September, 2022)
  6. #4
    Supas's Avatar
    Jun 2020
    [CITA=crouchinggerbil;4060481] Puede utilizar la versión más reciente
    de odis-s 7 https://www.digital-kaos.co.uk/forum...ING-ACTIVATION [/QUOTE]
    HI
    Can I install this version to continue using my VAS 5054?
    You were very nice and activated ODIS Service 7.2.1 for me but I can't use it with my VAS5054 ..
    Thank you
  7. The Following User Says Thank You to Supas For This Useful Post:
  8. #5
    Aug 2020
    Quote Originally Posted by Supas View Post
    HI
    Thank you[/QUOTE]
    Did you use the fix for the 5054 that was included in the download?
    Engineering you can forget about from 13 and 14. 5054 can only e used as passthru device but it is not full passthru protocol.
    Here is installation video https://www.youtube.com/watch?v=gg2pLNiuu2o
  9. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    Supas (30th August, 2021)
  10. #6
    Feb 2021
    Thank you for this . I also will try it .
  11. #7
    May 2014
    hello !! anyone have an older version of odis?? pls
  12. #8
    May 2014
    i need version 4.4.3
