Results 1 to 15 of 17
    right here right now
    Default bmw e92 320i nox/lambda delete
    I,m seeking help to delete nox and lambda on this 2008 320i with ecu siemens MSD80.2 5WK93643 if possible,file attatched,
    bmw e92 320i full.rar
    thank you.
    Feb 2021
    Norway
    Quote Originally Posted by smokinjoe View Post
    thank you.
    Cant find nox file in the file, so i cant do something with thatone.
    But i deleted lambda.
    Dont forget to thanks and rep
    Pass will you get in PM.
  3. The Following User Says Thank You to mortex For This Useful Post:
    smokinjoe (9th February, 2021)
    Thanks,much appreciated, For nox I have dtc P125B,is it enough to delete this one dtc or is my file bad?
    Sent from my SM-G973F using Tapatalk
    Okay to update I wrote your file and drove the car and it appeared to run alot smoother but only for one day,eml came on and dtcs I have now are as follows,
    2C7F lambda control 2
    30E4 nox sensor ageing
    3104 rough running, stratified charge mode
    Original dtc's were
    30DC nox sensor heating
    2C6C mixture control to cat
    2FC0 fuel pressure measurement range
    I would really appreciate any thoughts on what would be the next step forward to solve these issues,
    Thankyou.
    Still need help with this one if any members can assist,
    Thanks.
    Dec 2018
    Default Bmw Nox Off
    Frend. Your Nox off. Giv thenks and pass in priv
  8. The Following User Says Thank You to elektronik325 For This Useful Post:
    smokinjoe (20th February, 2021)
  9. #7
    Quote Originally Posted by elektronik325 View Post
    thanks i will test and report,do i need to unplug nox sensor?
  10. #8
    Dec 2018
    No problem. You can disconnect, but you don't have to. Recently i have done in 1 bmw. And I checked if the ankle was fastened or unfastened there was no DTCs.
  11. The Following User Says Thank You to elektronik325 For This Useful Post:
    smokinjoe (21st February, 2021)
  12. #9
    May 2017
    Solved or still ne help with?
  13. #10
    Quote Originally Posted by Lambda1 View Post
    Hopefully solved, I will test elektronik 325 file this week and report
  14. #11
    I have used your file and now after a short drive I still have still dtc 30DC nox sensor heating, maybe should I disconnect nox and write again?
  15. #12
    update, i have disconnected the nox sensor and rewritten file from elektronik325 and now have a permanent dtc 2EAE No message from nox sensor.
  16. #13
    here is latest read with nox disconnected, dtc 2EAE no message from nox sensor 1,also have dtc 2E85 Coolant pump and 2EF5 map thermostat if they can be deleted too
    bmw 320i last read.rar
    thanks again
  17. #14
    May 2017
    2E85 somebody killed dtc of this in file.
  18. The Following User Says Thank You to Lambda1 For This Useful Post:
    smokinjoe (24th February, 2021)
  19. #15
    Great job, worked a treat, thanks again.
