Results 1 to 5 of 5
Hybrid View
    Jun 2008
    Default kali live usb repair?
    kali live usb/win7
    MY pc was booted from the live usb (persistence), while in the suspended state it was removed. I guess it was corrupted as it will not boot from persistence now although it will boot from 'live' and 'fail safe' etc. Is there a way to repair persistence or will I have to format and start again?
    Feb 2021
    Based on the info you provided the fastest and easiest way would be to create a new bootable USB if you don't have any important files there.
  3. The Following User Says Thank You to kpme For This Useful Post:
    mikk (11th February, 2021)
    toyota123's Avatar
    Sep 2019
    Quote Originally Posted by mikk View Post
    kali live usb/win7
    it will not corrup beacuse the live pc uses RAM to run OS from usb .... i think there is another problem , if you can explain more detailed i will help you .....
  5. The Following User Says Thank You to toyota123 For This Useful Post:
    mikk (14th February, 2021)
  6. #4
    Jun 2008
    It attempts to boot then hangs before the kali menu screen. Not sure a screen shot is possible. The last line of script when it hangs -"Failed to start Daily man-db regeneration"
    Went the format route but when I try to mount partition now I get - mount: /mnt/kali: can't read superblock on /dev/sdb1. Any ideas?
  7. #5
    toyota123's Avatar
    Sep 2019
    it seems you have problem with drive sdb1 ...... and make sure you are ROOT ...
