Page 1 of 4 1234 LastLast
Results 1 to 15 of 52
    Default Mb Star DAS Fault
    Hi All,
    Bought a multiplexer kit some months ago from china. Used it a handful of times and it worked fine. However using it this morning it brings up a fault
    Fault (1.1)-1.501.9302
    initialization of multplexer failed
    Possible causes:
    The link between the multiplexer and diagnostic is interrupted
    The link betweeen the multiplexer and diagnostic unit is interrupted
    The voltage supply at the diagnostic socket(circuit 30 and or 31) is faulty
    When using sd connect, check the connection status using the toolkit.
    Just though I'd mention the kit has been in the trunk of my car for about 6 weeks, some days did get -8 degrees celsius although I'm sure that shouldnt make any difference. I have also warmed the unit up in the house with no joy.
    Any ideas?
    Run cesar selfdiagnostic in star utility.
    Write the result.
    you can use the self test on STAR Utilities and try what is the problems then after selftest you can got a result for it
    Quote Originally Posted by Room View Post
    Write the result.
    Dont you need a special lead to run the self test??
    I tried it but can't really understand what to do.
    Write the result.
    Also does the unit have to be connected to the vehicle to do a cesar test?
    Run STAR Utilities then Self Diagnosis and CAESAR Self Diagnosis.
    Unit must be power up ( led must be light).
    You can do it by connecting to the vehicle or simply supplies power ( if you use OBD, pin 4 is GND and pin 16 is +12V )
    The standard setup should include the 4-pin diagnosis cable which is easy to connect to a power supply.
    I have the same problem, below is my diagnostic result.
    CAESAR STOS+ Rev.:2.10 from Mar 11 2004
    generated protocol file from 19.02.2010 09:12
    SystemCheck :
    Check serial ... 0 Ok
    CAESAR HW Detection :
    D2Access ... 0 Ok
    D2DownLoad ... 0 Ok
    CAESAR Part D2 detected on COM3 with baudrate: 19200
    CAESAR version check :
    D2CheckSNVER ... 0 Ok
    User is Daimler-Benz AG
    User Authentification 1
    Classification 0
    Serial Number 123456
    Authorization Level 3
    Part D
    Hardware Authentification 010202
    Hardware Date 080103
    Special EEPROM check :
    D2 Special EEPROM check:
    Inst. date registered ... 303 Not possible to test this version of HW
    D2 Special CAN Test :
    Special Test ... 0 Ok
    Classification 0
    Part D
    Slave check :
    D2 Slave check
    D2 Processor ... 0 Ok C165 (mask step HA) is mounted.
    D2 RAM ... 0 Ok
    D2 FLASH ... 1703 Error occured while erasing FLASH
    D2 EEPROM ... 1802 Error (access to EEPROM)
    D2 SERCTL1 ... 0 Ok
    D2 UART1/2 ... 0 Ok
    D2 ADC ... 0 Ok
    D2 Display Power Supply :
    D2 Power Battery ... Voltage KL30 = 12.1 V
    D2 Power Ignition ... Voltage KL15 = 00.3 V
    D2 Voltage K-Lines :
    D2 State K-Lines (35) ... Total 1 (+), 34 (-)
    workshop
    wich DAS have you install?
    4/09 and 8/06 both give same error message.
    yuo must change COM3 to COM2
    I have an original MUX and it's working fine with the same PC so the problem must be in the Chinese crappy MUX.
  13. #13
    In my china multiplexer was burned RESISTOR
    sorry for my english
  14. #14
    The mux is out!
    Replace flash memory!
  15. #15
    I will take it apart, take pictures. Would you be kind to tell me what flash I need to replace?
