hello i need mileage old is 32... miles new please 27... miles dash bmw G series 2016 35128
i read this via vvdi prog but file size is 2kb not 16kb someone know if i write this 2kb wil be ok?thanks.
Medeonne (6th November, 2023)
I Think You Make A Mistake In Choosing The Eeprom, This Dash Have Two Eeprom Next To Each Other, One 35128, And Other 35160,
The Right Eeprom Is 35160, Read It And Post Your Dump Here.
Good Luck
IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
Yes, You Can Check It By Yourself, Can You Confirm That There Is Two Eeprom Next To Each Other ?
solved, vvdi reads via 160xxx. 2kb. but enough to change the mileage
Thanks again anyway.
Dis you manage to change miles with vvdi and 160dxxx
Maybe they use the eprom emulator??? I have not heard that VVDI could erase the first two lines of ST35128
I have a vvdi 3516WT adapter, I successfully erased the eprom until 2019.
