Results 1 to 5 of 5
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Default 2005 Merecedes AMG CLK55 Need Mileage
    Reading 172k right now need it to read 163k or so in that area. I'm robbing this from another cluster because the original file I can't seem to get it to work. It's either corrupted or I dunno what the heck. It says it's stuck in Neutral or "Shift to neutral". Original reads 163,209.
    Both files are included.
    Rerouter's Avatar
    Jul 2014
    Australia
    This should be it
    A file for feedback, This is all that is asked on this site, Did it work? what value appeared on the dash? maybe some photos or a power-up,
  3. The Following User Says Thank You to Rerouter For This Useful Post:
    tfourk (15th February, 2021)
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Quote Originally Posted by Rerouter View Post
    This should be it
    Flashed your file and I got this.
    I tried other alterations of the file. But every time I flash a change the screen whites out. Any suggestions out there? Using Arlabs box. Smelecom reads, but can't write.
    Last edited by tfourk; 15th February, 2021 at 04:15 AM. Reason: adding a bit of missing info
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    So I didn't want to let this post die. Here is a follow up to what happened. We managed to get the file again from the original chip correctly this time. Please note the cluster still shows "Shift To Neutral" since we resoldered the original chip back on to the board. Posting the file this time to see if anyone has any insight. We tried putting this file on a AMG same model number and the results were a black screen. Even as the file is posted now I still question it's integrity. Mileage is fine in this file.
    Aug 2019
    Here a virgin file
