Results 1 to 4 of 4
    Jan 2018
    Default reading 6LP1 ecu with Carprog ?? possible
    hi folks , i need to know if i can read the Magneti Marelli IAW 6LP1.02 with carprog ,
    i can connect te 12v and the kLIne and ground , but which eeprom i have to chose
    Help
    Jan 2018
    any ideas ??????
    right here right now
    These can be read with vvdiprog,upa,xprog not sure about via k- line ,memory should be st10f280 if I remember correctly.
    Sent from my SM-G973F using Tapatalk
  4. The Following User Says Thank You to smokinjoe For This Useful Post:
    constantinexx (16th February, 2021)
    Jan 2018
    in the ktag will be used the boot mode through a gray wire "boot""
    in car prog there is no boot but BKGD , can that works ??
