Results 1 to 15 of 16
    srt8's Avatar
    Nov 2017
    Default 9S12 PROGRAMMER NEEDED
    Hello everyone, i am looking for a good programmer for mcu 9s12 family that can also work with XEQ, and other masks. i have tried VVDI prog, not good, r270, not good, xprog, not good. what else is out there you guys can recommend? r270 and xprog are clone units, maybe that is why, i do not know.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by srt8 View Post
    What do you mead all that programmer not good? have you check your connections?
    bearheroes's Avatar
    Dec 2011
    Then try ori xprog and then tell us if not good...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    srt8's Avatar
    Nov 2017
    Quote Originally Posted by bearheroes View Post
    What do you the professionals use? Besides the listed above units
    srt8's Avatar
    Nov 2017
    Quote Originally Posted by Panathaole View Post
    Sometimes won’t read or writes and damages the mcu
    g5n14's Avatar
    Aug 2018
    Worked with everything you have mentioned. I know its kind of luck, but among 100s of processor i have never killed a single one.
    With all the respect possible, develop your research and soldering skills. WIth right pinout and decent connection - even 40quid R270 will never make a brick.
    Even old-ass 5.55 Xprog clone for 50quid will read everything except XEP100. But VVDI Prog so far - best tool in my personal opinion, completely bugless with 9s12.
    But for XEP100 BMW i use Yanhua Mini ACDP - reads those without soldering which is very time efficient. Very handy in case you do a lot of BMW mileage or keys, or maybe you are not so sure in your soldering skills.
    bearheroes's Avatar
    Dec 2011
    Ori xprog always read and until now never destroyed anything.
    brend's Avatar
    Oct 2015
    Same where
    So mate if all this tool for you is bad....probably programming job not for you!?......cooking.gif
    Mar 2019
    Earth
    VVDIPROG best tool on the market as for programming modules ,but it works as a DUO (programmer + well prepared technician)
    bearheroes's Avatar
    Dec 2011
    Quote Originally Posted by 12manux View Post
    If vvdi is the best then what about xprog ori? Or upa-s?
    brend's Avatar
    Oct 2015
    Same where
    +/- it's not 100%!!!
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    xprog is a really good programmer...
    but for example...
    9s12xep768 (reball) in circuit no connection, installed in Harley davidson ecuīs...
    also same with smok...
    with cg pro/UPA/vvdi prog no problems with reading/writing...
    but in generally xprog a really good tool...
    since 6.5 in combination with win10 newest updates, I canīt see ADOBE help files longer...
    on win7 all ok...
  13. The Following User Says Thank You to figani For This Useful Post:
    srt8 (17th February, 2021)
  14. #13
    srt8's Avatar
    Nov 2017
    I had vvdi prog, couldn’t read the XEQ, but read it well with xprog, clone. In regards to xprog or r270, I can’t get it working with the Benz Eis w211 ST or HC12 MCUs. But the original R260 read it well, but not my tool, had to borrow it from a friend. No issues with soldering there, so........and in regards to CGDI 9s12, never used it but heard bad things don’t want to risk it. Thank you guys
  15. #14
    srt8's Avatar
    Nov 2017
    Quote Originally Posted by brend View Post
    My soldering is ok, and programming not an issue. I had no issues with the original R260, but it was not my tool, I have to borrow from a friend.
  16. #15
    Mar 2019
    Earth
    I work on immobiliser area mainly ,and vvdiprog did an awesome job so far (CAS for BMWs,EIS for Mercedes,FRM for BMW,UCH renault,J518 vag ) it paid for it self 10 times or more.
