Results 1 to 2 of 2
    Netherlands
    Default W117 Full LED, lights coding
    Hi all,
    I have Mercedes W117 from 2016 with both front head lights coding as right lamps. It mean when i put left turn signal there is nothing happen in from lamps, rear works properly (left side turn signal),
    when I put right indicator, in left and right front lamps are flashing turn signals, rear work properly ( right side turn signal). in short. In xentry there is not left LED module there is only right LED module.
    How to switch in one module coding from right side to left. I already check GND to pin 53 in left lamp and everything is ok.
    Best regards.
    impossible is nothing...
    Feb 2020
    Polska
    Hello, VW T6 2018 replacement of the front headlights with full led, I reworked the installation for both lamps. Installed sensors and headlight leveling module with sensors. The option in the gateway enabled channel 55. I have BCM coding as in the pictures, what should I change so that I don't have a message of burnt bulbs and everything shines correctly? Now I don't have a parking light with headlights in front
