Results 1 to 6 of 6
    Jul 2009
    Default toyota highlander virgin file
    please i need the vigin file or immo off for this toyota highlande .ecu no; 89661-0c200 4X4 2UZ TN275000-0722 DENSO. [93c56],does this car has immo box?i serched but could not see any.attached is the dump i saw in the ecu 93c56,the key keep on flashing
    Nov 2009
    Szczecin;Poland
    This is virgin file. Upload to ecu and turn ignition on with your original key.
    Jul 2009
    thanks all the car have started with the virgin file
    Mar 2010
    por favor quero a reset ou decode da toyota rav4 89661-42d20 se possivel com imagens
    May 2010
    Is it possible to upload these files straight to the ecu or do you need to remove the chip?
    Jul 2009
    i have another toyota seqire,all keys lost thesame ecu no.. i used the above virgin dump but the key light still flashing,attached is the dump i saw in the 93c56 eeprom
