Results 1 to 4 of 4
    castin's Avatar
    Oct 2015
    Poland
    Default Renault Clio IV HFM HFM data corrupted after power down.
    Guys, i hawe this situation. After power down, the HFM stop recognize all two card - no ignition, remote not work. Im read processor in HFM (car is 2018), RET can't read ISK/PIN CODE with dump. Data_flash in HFM looks like corrupted, many FF, status HFM in RET is "clear". Can i learn virgin (another) HFM using RET without PIN CODE/ISK? Or maybe it's possible repair data_flash?
    Dec 2016
    Quote Originally Posted by castin View Post
    Simply read by OBD2 the PIN code using <Read Identification> button of R.E.T , if you can't > renault.net in main dealer
    Normally in this case disconnect battery 10 minutes can resolve this problem , if not > renault.net in main dealer
  3. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    castin (26th February, 2021)
    p1et's Avatar
    Oct 2013
    You need original car PIN code to learn virgin HFM so when original HFM dump is corrupted and no PIN code inside, only dealer can help you.
  5. The Following 2 Users Say Thank You to p1et For This Useful Post:
    castin (26th February, 2021), fred77 (19th February, 2021)
  6. #4
    castin's Avatar
    Oct 2015
    Poland
    Yes p1et, car go to dealer, don't hawe oryginal PIN/ISK.
  7. The Following User Says Thank You to castin For This Useful Post:
    TERMINATOR1000 (26th February, 2021)
