Hi my friend. They said something while programming. As for the pin, you would have to read it from the immo (meter) I can clean the driver and vcds you will add it. Because you won't get the pin from this file.
And how do you connect vcds, what are your errors in the engine? You need to read the eeprom from the engine edc. Because the flash will not help
