Results 1 to 11 of 11
    Oct 2017
    Default Polo 6R0959655K fault B2000
    VW Polo 6R Airbag module 6R0 959 655 K, 0 285 010 793 HW:09 , SW: 0020 year 2010, there are many mistakes among others, Fault B2000 00 (137) (153) Internal Control Module Memory Check Sum Error, atach 95320.
    Jun 2013
    canada
    your file cleared
    try and report
    pass in pm
  3. The Following User Says Thank You to ismili1967 For This Useful Post:
    Elektron1 (21st February, 2021)
    Oct 2017
    Not ok cannot be deleted 3 Fault 0002 -Internal Control Module Memory Check Sum Error B2000 00 (137), 0006-Internal Control Module Memory Check Sum Error B2000 00 (137), 0064-Internal Control Module Memory Check Sum Error B2000 00 (137).
    BR.
    Jan 2019
    try this
    pass pm after press thanks + rep button
    from brazil
  6. The Following User Says Thank You to reeenanrex For This Useful Post:
    Oct 2017
    you did not submit the password .
  8. #6
    matik185's Avatar
    Jun 2018
    Europe - PL
    Quote Originally Posted by Elektron1 View Post
    here you go .. please test
  9. #7
    Oct 2017
    does not work
  10. #8
    matik185's Avatar
    Jun 2018
    Europe - PL
    What DTC are stored ?
  11. #9
    Oct 2017
    Quote Originally Posted by matik185 View Post
    0002- Internal Control Module memory Check Sum Error B2000 00 (137), 0006-Internal Control Module memory Check Sum Error B2000 00 (137), 0064-Internal Control Module memory Check Sum Error B2000 00 (137)
  12. #10
    Jun 2013
    canada
    try clear 2
    same pass
    or try clear all
    same pass
  13. #11
    Oct 2017
    The three mistakes Cheksum error I mentioned do not disappear.
