Results 1 to 3 of 3
Thread: Ford Kuga p025b
    Feb 2018
    Default Ford Kuga p025b
    Ford Kuga 2, 2.5 petrol, starts for 2-3 seconds and die(fuel pump stops), sometimes have dtc p025b, had check wiring fpcm( set new wires direct pcm-fpcm), try another fpcm, another fuel pump, pcm and bcm updated with last firm, no crash data, car had welded with disconnected negative battery terminal, any idea?
    Feb 2021
    Immobilizer is stopping engine running??, Some VW model allow car to start, but cut off 2-3 sec after, check security light on dash
    Nov 2017
    it is not immo. test rail pressure min 2Bar. Watch on live data and check fuel pressure sensor. But in most case is plug from pump or short to ground.
