Results 1 to 5 of 5
    Jan 2020
    UK
    Default P31658440 VOLVO no communication
    Hi guys !
    I have big problem with srs module.
    After clearing crash data module is not visible to the car .There is no communication,
    Does any one experienced similar problem ?
    What it can be ?
    matik185's Avatar
    Jun 2018
    Europe - PL
    It looks like a bad file or hardware problem..
    Post your original dump - before you modified it..
    Jan 2020
    UK
    there is a file
    superjet's Avatar
    Aug 2018
    try this one....
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    I've came across this fault before, if "low battery, eco mode" is on dashboard it won't power airbag ECU.
    Ended up taking ECU out of the car and testing on bench and it communicated ok >.> Charged battery for 30 mins started engine all lights went out.
  6. The Following 2 Users Say Thank You to AB4S For This Useful Post:
    slick_dick (24th February, 2021), superjet (24th February, 2021)
