Results 1 to 8 of 8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default Pt cruiser strange problem
    Pt cruiser 2006,diesel.
    Key guitar shape chip onboard.
    Problem is with remote.
    There is 2 ori keys,earlier both worked ok.
    Now only 1 key remote work.
    Take fully working key, remote ok. I turn ign or start car,no matter. Car recognize immo light off. After remove key remote not workinh anymore. Remote starting work on other key which not worked befire start car. That i take that key,do same like first ,start car etc. And remote start work on first key and on second no more.
    Its like 1 key kicks out other in a row.
    Stick one stick other,remote work on one ,later on other
    Anyone knows something about this?
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Is it possible, that the remotes were stored on the same place? Eg: both keys are on the first position
    Did you tried to remove all keys and reteach them?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Hows that possible on same position with diferent id its not copy chip with separate remote. This problem occured not long time ago. 5 year was ok.
    I not tried relearn nothing for free first inquire maybe someone had this
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Ohh I C...
    The guitar shape alone makes it not clear enough...
    I would suggest cables check, I think the mices were active...
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Read again 1st post. If no remote work than maybe,but not this case
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by drugowaz View Post
    Read again
    What a shame! Do you think that I can read?!?!
    ray-ray's Avatar
    That happen when you clone a RHK. The key you clone starts but the original stop working the remote section, till you cycle the key in the ignition.
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Yes i would agree. But in this case nothing done to car. It happened by it self. You think make new key will solve problem?
