- have you ori dump from ecu?
- you should virgin bsi and adapt to car
- bsi - is it same as ori one ? - i mean flash
if you will answer - i will post next steps
Hello guys,i have problem with PEUGEOT Partner, 1.6 HDI, 2009...After BSI change and immo off in ECU´s EEPROM 95160 the car will not start. The dash display write " Economy Mody Activated". The eeprom in old BSI was erased behind Abrites mileage change, so it was replaced with another one.
So should I make some modification in replaced BSI or ECU´s flash (EDC16C34)?
could someone help me? Thanks a lot
need help
now my goal is to buy xp-005
who will help?
tommyno18 (25th February, 2021)
Hssn (12th June, 2023)
pin ori from ecu - C34P
eeprom bsi - looks bad - what type of eeprom inside?
i missed this: as you wrote was erased behind Abrites
do not worry
we will try back your ori bsi to work
- connect bricked bsi again to car
- connect fvdi and read what software signature have you got
- after that - i will try to find flash same as you have - and you will write by fvdi
( eeprom not cleared by fvdi - only flash bricked )
need help
who will help?
I dont know, red it with abrites...Now i have at home the erased BSI, i can look and let you know
need help
who will help?
Check if settigns on BSI for Gearbox is not set to Automatic Gearbox, If so car won't start if it has manual transmission.
Ok mate, tomorrow i´ll be in garage by he car and try to do steps you´re wrote...Thanks for this time, have a nice evening
connect bsi on bench.................then try again
need help
who will help?
tommyno18 (27th February, 2021)
