mitsubishi L200 2020 clear crash
Results 1 to 8 of 8
    Jul 2018
    Chile
    Default mitsubishi L200 2020 clear crash
    hi forum i need clear the data for this module:
    8635 A 359
    3SR737
    W2T90171
    mitsubishi l200 2020
    Eeprom S25A16 - 95160
    DTC B1509 permanent in the memory
    Jun 2013
    canada
    try and report
    pass in pm
  3. The Following User Says Thank You to ismili1967 For This Useful Post:
    Dflowd (28th February, 2021)
    Sep 2019
    Default try this
    hi, try this file and report, it should works
    thank + rep if it works
    cheers
  5. The Following User Says Thank You to SeanRR For This Useful Post:
    Dflowd (1st March, 2021)
  6. #4
    Jul 2018
    Chile
    hi, the file not work
    code B1509 and now B1519 present in the memory,
    do you have other solution?
    Jul 2018
    Chile
    Quote Originally Posted by SeanRR View Post
    cheers
    the file not works code B1509 present in the memory
    i try the elminiate with diagnostic tool but not works
  8. #6
    Jul 2018
    Chile
    anybody have a solution for this?
    thanks for you help!!
  9. #7
    Aug 2016
    Quote Originally Posted by Dflowd View Post
    Try this solution
  10. The Following 3 Users Say Thank You to lukasz12345 For This Useful Post:
    ACHRAF87 (28th January, 2022), Dflowd (1st March, 2021), ngetniko (14th March, 2022)
  11. #8
    Jul 2018
    Chile
    Quote Originally Posted by lukasz12345 View Post
    Try this solution
    thanks, the file works.
    information: disconect the left conector (front view) and delete dtc, switch off
    later conect the plug switch on and delete dtc again.
    works for my, maybe someone will use this!
    thanks!!!
  12. The Following 3 Users Say Thank You to Dflowd For This Useful Post:
    ACHRAF87 (28th January, 2022), lukasz12345 (1st March, 2021), ngetniko (14th March, 2022)
