Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
shooting (2nd March, 2021)
you have thy in bdm and is not possible? in car ecu is visible?
to use only eeprom it probably works if you have the same sw number of flash and micro....
PCB1.JPG there are mising block condesator like this i show you on picture,but it works without it.your problem is first leg on stabilizator,just solder first pin on place i send you and ecu will work
need help
now my goal is to buy xp-005
who will help?
rafal (2nd March, 2021)
sorry on my English capacitor missing but it works without it , first leg must be in connect with resistor 100 ,and when you connect on board on last leg you must have 2.6v
shooting (3rd March, 2021)
if you cant read with bdm then mpc is damaged or flash
normaly its the mpc that needs reballing
the capacitor thats missing wont effect the reading or writing
if you get another ecu iether with same hardware and sw numbers all you need to do is take the eprom from that ecu and place it in the new ecu
if you get another 603 ecu thans not the same numbers then rewrite the flash and mpc with these files (full backup of whats in your flash and mpc) and use your eprom file or ic
