Results 1 to 13 of 13
Hybrid View
    italy
    Default citroen c3 pin code from bsi help
    please help with pin code from bsi citroen c3
    siemens s118085200
    eeprom 95160
    Crasftsman's Avatar
    Oct 2017
    Quote Originally Posted by ingenton View Post
    siemens s118085200
    eeprom 95160
    pin code. PKXR
  3. The Following User Says Thank You to Crasftsman For This Useful Post:
    ingenton (2nd March, 2021)
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    siemens s118085200
    eeprom 95160
    VIN : VF7FC8HXB26***342
    PIN : RXKP
  5. The Following User Says Thank You to CarCity For This Useful Post:
  6. #4
    Hello, can you tell me PIN from this dump ?
    kiszka's Avatar
    Quote Originally Posted by emes125 View Post
    >>> RSE7<<< or vice versa
  8. The Following 2 Users Say Thank You to kiszka For This Useful Post:
    emes125 (15th July, 2022)
  9. #6
    Quote Originally Posted by kiszka View Post
    Code OK, car still not starting, P0215
  10. #7
    Seemingly I burnt eeprom. Was this a correct file ? Can you decode its VIN ?
  11. #8
    kiszka's Avatar
    You didn't burn anything, the brain of what it tells you is burned
  12. The Following User Says Thank You to kiszka For This Useful Post:
    emes125 (9th July, 2022)
  13. #9
    Unfortunatelly car is not starting, and there is no reaction to remote control. Should I buy new BSI, and "virginize", and later program it using PIN you sent me ?
  14. #10
    kiszka's Avatar
    read ecu eeprom
  15. #11
    Code RSE7 was ok. Thank you. I did Lexia programming to BSI, but car is not starting. I can read P0215 in ECU. Relay on BSM ?
  16. #12
    Jan 2023
    Ola preciso codigo pin bsi delphi c3 2008
  17. #13
    Jan 2023
    Ola preciso do pin c3 vin VF7FC8HZC29166404
