Results 1 to 11 of 11
    vuno01's Avatar
    Europe
    Default opel corsa 1.3 cdti mjd603.s7 dpf
    hello guys can anyone please help with this mjd603.s7 dpf off
    i have done it with dpfremover and with volta but i still have dtc p2452
    and cant erase it
    if anyone can help i really would apreciatte, i have uploaded the original 2mb flash m58b
    vuno01's Avatar
    Europe
    ok
    so i solved it my friends.
    here is the story...
    had a corsa d 2008 with a mjd603.s3 ecu damaged by water so i replaced it for a mjd603.s7 but the s7 has dpf and the car originally did not
    thats why i wanted to remove it...
    anyway i have used the m58b flash from the s3 and the mpc also from the s3 and because i have already program the s7 ecu to the car, i used the s7 eprom and that was it. and the car is running flawless now.
    hope this helps someone.
    regards
  3. The Following User Says Thank You to vuno01 For This Useful Post:
    Yhoni (14th April, 2021)
    Aug 2008
    could you post or send me the bdm files please
    is it 55571621MZ ?
    vuno01's Avatar
    Europe
    i dont have the car with me anymore so i dont know if thats the correct number.
    but maybe i can see it in the dumps.
    wich one you need the s3 or the s7
    Aug 2008
    the s7 i think mpc/flash/eprom
    vuno01's Avatar
    Europe
    this is the dumps for the mjd603s7
  8. The Following 2 Users Say Thank You to vuno01 For This Useful Post:
    Kayhan 17# (7th April, 2024), tango (22nd March, 2021)
  9. #7
    Aug 2008
    cheers this is 55186423 and the pin 1869
  10. #8
    vuno01's Avatar
    Europe
    the pin is correct as i remember but sw i really dont know
    maybe i can send you the s3 dumps and you can see if it works for you
  11. #9
    Aug 2008
    yes post the s3 dumps too maybe they are good too
  12. #10
    vuno01's Avatar
    Europe
    this is the mjd 603 original dumps
  13. The Following User Says Thank You to vuno01 For This Useful Post:
    tango (18th April, 2021)
  14. #11
    Aug 2008
    55568383 KZ with same pin 1869
