Hello Friend. I would check the air flow meter. What is its value. Because I bet it's damaged. You can also try to blind the EGR and see how the car will go and what is the value on the air flow meter
Hi all, i have a problem with a bmw 520d lci 2007
the car is in limp mode with the check engine on, dtc P3263, i have a interrupted acceleration with smoke
HW: 08506199
SW: 1037396562
SW upg: 08506842
Spare: 08506838
that is the file from the car, but i think is not a good file, its not correct modified
if anyoane have a solution for this car, a ori file, a good modified file with swirl flaps off,dpf,stage
The file is read with Ktag clone
I already changet the air flow meter, But same problem.
Try to mechanically plug the EGR valve with a plate
Dont work..., Any other solution? A File, stage, ori ?
send stock file pls
Hi my friend. Well, you can try to upload ori as you have. If you do not have it, tomorrow morning I will check if I have such a file.
I dont have ori file...
Anyone With a Original File ?
