Results 1 to 7 of 7
    Cambodia
    Default key program for vw beetle 2001 help please
    Hi all member have any one got experience on programming of transponder key for vw beetle 2001 no luck all the time because this is first time for me to do this vehicle , please anyone can tell me how to program this key I use 48 crypto and vag K+can commander full version 3.00 (from china) , I try read out pincode from instrument cluster Magneti Mareli -shadow (passat) but pincode is wronge and appeared Fail on the dash
    Thanks in advance
    pepi's Avatar
    Quote Originally Posted by soksopheak846 View Post
    Thanks in advance
    In a lot of times the cloned vag K+CAN commander fails to read the pin code . Do you have any other tool for this?
    Cambodia
    thanks for your help I have super vag K+can , can you recommend me what programmer should I buy to do this job for vw
    Best Regards
    Busswil Switzerland
    what engine is diesel or gasoline. if is diesel you can read ecu eprom to find pin codeor or vagtacho2.5 or higher. for programing you can use vcds.
    maaxxyy's Avatar
    North Pole
    I have posted vag immo login tool on here somewhere, do a search! This should be able to read the login code needed, this works by k-line interface. Then vagcom to adapt the key.
    Ashraf6119's Avatar
    UK
    Hi Soksopheak846,
    Try reading pin code with T300, MVP, or Vag-Tacho 2.5 as adviced by Babanovski.
    Also you should remember one thing ever time you put wrong pin code the ECU lock Time is Increasing so make sure you live the Ignition ON for some time before you start to program keys.
    Also Battery should be fully charged all time.
    Or if you have Vag-Com you can check lock time in Instrument 17, Groupe 21 or 22 can't remember.
    Hope This Helps.......................................
    Ash
    Maaxxyy
    What Tool you talking about i have not seen any so could you please post the link for it.
    Ash
    Greece
    my friend you can find a lot of information for how to do the key matching procedure here:
    Ross-Tech: VAG-COM: Immobilizer Info
