BMW 320D EDC17CP02 EGR OFF
Results 1 to 8 of 8
    Jan 2021
    Hungary
    8
    Default BMW 320D EDC17CP02 EGR OFF
    Hi!
    I have an EDC17cp02 ECU.
    sw: 1037399763
    I tried both ADS and Professional EGR remover and tought this should work. First when I've written the ECU the EGR valve were in place. I know if you OFF the EGR it doesn't mean it is 100% closed, so I decided to blank it between the EGR cooler and the engine. After that the engine had more less power. So I think the ECU still expects air from the EGR. Didn't get any DTC's but definitely less power, so it not works as it supposed to be.
    My question is, which map should I modify if I want to blank the EGR? I found the histerysis maps made some modification but did not do the trick. Now the car has downpipe and switched off the DPF too.
    Any help would be greatly appreciated.
    Emil
    pike's Avatar
    Sep 2013
    1,815
    still believe in magic of free software?
    Jan 2021
    Hungary
    8
    Can you point to the solution? There are 4 hysterisis maps. 52F5A, 53048, 6D622, 6D6E8. Should I set to 0 all?
    Jan 2020
    Romania
    23
    for EGR you have to set values to 0 on the hys maps
    1st - 52F58 14x1
    2nd - 5303C 14x1
    dpf switch - 704B4 -1x1 (in your file is on btw)
  5. The Following User Says Thank You to nusuntcatalin For This Useful Post:
    Emil98 (6th March, 2021)
    Jan 2021
    Hungary
    8
    Quote Originally Posted by nusuntcatalin View Post
    1st - 52F58 14x1
    2nd - 5303C 14x1
    Exactly what I wanted to know, thank you. Yes the DPF switch is on in this file, because it is the original file.
    So if these maps are set to 0 I can blank the EGR right?
    Jan 2020
    Romania
    23
    Yes. Da Emile, daca le pui pe 0 e anulat
  8. The Following User Says Thank You to nusuntcatalin For This Useful Post:
    Emil98 (7th March, 2021)
  9. #7
    Jan 2021
    Hungary
    8
    So yesterday I made the changes, wrote the ECU, blanked the EGR ran some circles in the town and it seemed it works. Later when I stopped for about a half an hour restart the car, so the engine wasn't cold, the engine had less power again. Were not enough air probably. And today at the morning when ran some more circles to test it, the engine were cold again, and worked. No DTC at all. Any idea?
  10. #8
    johak's Avatar
    170
    restore all the dtc in the file, do a test drive and you will find out the problem yourself.
