    Oct 2015
    Default Peugeot 307 electric steering
    Hello
    I have problem with a Peugeot 307 with electric steering. The error code is C1200-internal fault.
    I have open the ECU and resold the PCB and car work fine for 1 days. So anyone have experience with reparing this modules.
    Mar 2020
    in the field
    hello, see the fuses under the bcm corrode the contacts
    Oct 2015
    Everything is OK. I resolder all joint and MCU and steering work fine for 1 day and now same error
    Feb 2021
    Resolder 2 smd caps...maybe help.
    Feb 2021
    check wiring loom next to water fluid reservoir ,can rub through
    check main fuse in engine compartment, it can burn up
    check hydraulic fluid in connection and wires at electric pump
    Oct 2016
    this is common problem with 307 steering works fine then no then works , go to bcm ( fuse box ) look under it for the big fuses 70 the leg of this fuse is escaping current
