Recovery pack for 3.02OE-A - 3.40OE-A
Results 1 to 13 of 13
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    68
    Default Recovery pack for 3.02OE-A - 3.40OE-A
    Well iv been seeing around that there are quite a few people updating there psp's to the custom firmware that Dark_Alex has provided us with. Many don't understand the recovery menu that well, nor do they know how to downgrade back to 1.5 via the recovery menu.
    -Why is this pack important?
    As soon as you update to the custom firmware its always a good idea to have the recovery files on your memory stick just in case anything were to happen that would intern brick your psp.
    -How to go back to 1.5 via custom firmware!
    1.download the recovery pack
    2.extract the content in the recovery pack onto the computer
    3.place the "RECOVERY" folder into the game folder of your psp
    4.obtain the 1.5 eboot. Rename it "UPDATE.pbp" and place it into the "RECOVERY" folder.
    5.Go to the recovery menu on your psp by turning off your psp. Then hold the R trigger and thus turn on your psp and you will be at the recovery menu. It should look like a purple screen.
    6.Go to the option "Run program as /PSP/GAME/RECOVERY/EBOOT.PBP
    7.hit X and the process of the downgrade will begin.
    Hope this helps!
    Thanks to gunntims0103.
    Get Digital Kaos on your Apple or Android device with Tapatalk
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    68
    Original file reuploaded.
  3. The Following User Says Thank You to Devilfish For This Useful Post:
    gmb45 (8th May, 2021)
    Jan 2010
    Default psp3000/3
    i dont suppose any one has found a way of down grading the psp slim 3000/3 and dont say pandora please dont say pandora it dont work on the new motherboard
    janobi's Avatar
    Mar 2008
    In a field.....
    3
    Quote Originally Posted by MasterMick1 View Post
    If your fw is higher than 5.03 then your doomed mate, and need to wait for an exploit to be found.
    For all those that have a pandora, this is unnecessary to DL, as pandora will return you to 1.5 if you wish.
  6. #5
    Mar 2010
    can you connect to a ps3 with a hack psp?
  7. #6
    Oct 2008
    is this 3004 psp as it does not need Pandora's battery try chicken hen first and then use installer and the psp 3004 will play the games in .iso format but you will need to make iso folder for the games and homebrew games just in the psp/game folder
  8. #7
    Nov 2013
    Default will this work with psp 1000 that is semi bricked ?
    Quote Originally Posted by Devilfish View Post
  9. #8
    Aug 2018
    Thank you!
  10. #9
    Feb 2019
    Default and Rawa wd aw da w
    aa d wd. wad ada wad wd and awn a wad wd a wd and a wd
  11. #10
    Aug 2019
    Quite old but will try it. thank you
  12. #11
    May 2020
    Is there other link to download this pack ?
  13. #12
    May 2020
    I could not download the file, has anyone have the recovery pack for 3.02OE-A - 3.40OE-A link Please ? Thank you
  14. #13
    Jul 2021
    How can I get the recovery pack?
  15. The Following User Says Thank You to Sushi1980 For This Useful Post:
    mojo20 (25th March, 2022)
