Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Mar 2017
    Default SCANIA pin form COO7.
    Greetings,
    Wanted calculate PIN from COO7 eeprom dump.
    Apr 2012
    BG V.T.
    No pin in the dump! Is COO locked ?
    Mar 2017
    I don't know about coo7 lock, ECU is burned . Before this TRUCK was working fine.
    I need PIN to marry new ECU with old COO7.
    Apr 2012
    BG V.T.
    If COO is unlocked , the encryption and pin code missing in eeprom dump. I don`t see codes in your dump - check COO status : unlocked/locked.
    Mar 2017
    Hello
    Here is other coo7 dump , are you see PIN ?
  6. The Following User Says Thank You to hyperlink For This Useful Post:
    yotrans (6th August, 2021)
  7. #6
    Apr 2012
    BG V.T.
    I don't see PIN . Do you check is the coordinator locked ?
  8. #7
    Mar 2017
    Hello,
    Here is coo sops ,please tell where i see it?
  9. #8
    Apr 2012
    BG V.T.
    SOPS file doesn't contain that info - inside no pins/keys and no lock status . Must check via diagnose SDP3 - is the coordinator locked or unlocked. If is locked then is possible to extract PIN from eeprom dump.
  10. #9
    Mar 2017
    Here is coo7 screenshot from SDP3, but without ECU impossible to understand locked or unlocked.
  11. #10
    Jun 2014
    ankara-turkei
    Default immo off
    you can use this tool from diagcode.com
  12. The Following User Says Thank You to caliskan71 For This Useful Post:
    Meat-Head (16th August, 2021)
  13. #11
    Apr 2012
    BG V.T.
    Here is locked coo7.
  14. #12
    Mar 2017
    Quote Originally Posted by caliskan71 View Post
    Can this tool calculate from dump ?
  15. #13
    Mar 2017
    Strange , my coo7 has unknow status in SDP3 without EMS on table.
    Calibration window is empty.
  16. #14
    Jun 2021
    hi , how to get it please i need it .
  17. #15
    minimex's Avatar
    Aug 2013
    EU
    >>> If I helped you please press Thanks and Rep. - Password only by PM <<<
  18. The Following 4 Users Say Thank You to minimex For This Useful Post:
    Bllinda (19th July, 2021), Dzeepromer (26th August, 2021), Meat-Head (16th August, 2021), WesleyMussum (29th March, 2022)
