andresvargas704 (16th October, 2020), rdjorge (11th March, 2019)
part # 3408501
Can anyone assist me:
Following error is displayed on HMI after installation of cense module part no. 3098771 (QSV 91 Gas engine):
- It shows negative 17 ( - 17 ) degree C on all 18 cylinders for exhaust temperature parameter.
I think this error can be fixed if the card is re calibrated.
How to calibrate the card? Which software? I Tried INSITE but not worked
If this is a CPG genset the HMI is usually from Siemens (all the ones I have seen are), they are programmed with Siemens Simaitic Step 7 software.
Can you see exhaust temperatures in the Cense module.
You have to install Insite for Cense (on the Insite CD ROM) to view Cense info or calibrate the Cense ECM.
I am unable To connect to Cense Module can you help
i am using inline V insite connects but insite cense unable to connect
Hello DK,
May I ask the difference between a Dominion type controller and a GCS? Cummins says that a Dominion controller cannot be calibrated by Inpower.
Thank you in advance.
the life is easy... people complicate!!!!!!!!
life is funny just step away of people that wants make your life a shixx
http://youtu.be/PEw3nYmpEys
