Page 14 of 15 FirstFirst ... 49101112131415 LastLast
Results 196 to 210 of 216
  1. #196
    Mar 2012
    your ecu is fine you just seeded it , you have to use a fleet calibration and reinstall the calibration , you probably just lost pc power or unswitched power.. it happens in our shop all the time , a feet cal would put you back on the road mate
  2. #197
    South Africa
    can anyone help with isx rom boot wire diagram or the pin location for rom boot switch
  3. #198
    Default rom boot isx
    Quote Originally Posted by jacques69256925 View Post
    http://www.digital-kaos.co.uk/forums...tml#post874690
  4. The Following User Says Thank You to alsop For This Useful Post:
    mang5087 (7th October, 2013)
  5. #199
    Dec 2010
    can any body help me... i am trying to fix a cm530 cense as it was showing all the exhaust temp. 17.8f on a QSK60, i tried clearing all the fault logs and trend logs and reset the cense, but i am unable to calibrate it. tried a lot many ways to do it, my insite cense option of calibration goes grey not letting me to calibrate, any suggestions to how to calibrate.
    i am working with bench cables 3163064
  6. #200
    DK Veteran Poptest's Avatar
    Sep 2010
    I am trying to reprogram a 3618046 Celect ecm but have been unsuccessful. When I try a calibration transfer, Insite displays this error code:
    "The connected ecm part number is not compatible with the selected calibration. Please choose another calibration with the correct ecm part number and try again."
    The calibration I chose was for a 3618046 and I am also sure that the ecm is a 3618046 as I was able to reprogram this before.
    And when I viewed features/parameters, the ecm had no part number. It just showed ?????????.
    Could this be the reason that it will not accept a calibration transfer?
    Please help me. What can I do to enter a new calibration.
    Thanks in advance..........
  7. #201
    Sep 2010
    Try to rom boot and load the cal...
    Please press thanks and + rep if i could help a little....
  8. The Following User Says Thank You to parezoo For This Useful Post:
    Poptest (6th October, 2013)
  9. #202
    Sep 2010
    Quote Originally Posted by parezoo View Post
    Thanks parezoo
    How do you perform a rom boot?
  10. #203
    Sep 2010
    Help was calibrating a Cummins Celect ECM, there was the problem of electric power and communication short after that I can not connect with insite, I have the blank ECM can do to calibrate it, your support will be very valuable
  11. #204
    Member jhon silva's Avatar
    Sep 2012
    Colombia
    Hello, please could help me with calibration files AX90076.04 for engine Cummins ISD.
    Thanks.
  12. #205
    Senior Member kitty-hawk's Avatar
    FRANCE
    Quote Originally Posted by jhon silva View Post
    Thanks.
    AX90076.11
    intelect.zip
  13. The Following User Says Thank You to kitty-hawk For This Useful Post:
    jhon silva (17th June, 2014)
  14. #206
    Sep 2012
    Colombia
    Quote Originally Posted by kitty-hawk View Post
    AX90076.11
    intelect.zip
    the CPL has the truck is 3602 but in 2014 this cpl Incal not shown me. Someone who can help me please
    the engine is ISDe number 4988820.
  15. #207
    FRANCE
    Have you engine serial number?
  16. #208
    Sep 2012
    Colombia
    87265070
  17. #209
    FRANCE
    AX90076.zip
    This is the latest version available from Cummins.
  18. #210
    Oct 2013
    Quote Originally Posted by fenomenoide04 View Post
    HI, I HAVE A CUMMINS ECM, I TRIED CALIBRATE IT, BUT IN THE MIDDLE OF PROCESS, THE SOFTWARE HAVE SENT A MESSAGE OF ERROR, AND NOW I CAN'T CONNECT TO ECM WITH CUMMINS INSITE... WHAT CAN I DO TO CONNECT??
    I have 2 celect plus ECM gone in RomBoot mode my customers asking me a lot of question for that, tell them they need a new one
