Page 2 of 15 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 216
  1. #16
    DK Veteran zds's Avatar
    Russia
    Hi. I tried calibrate Celect Plus m11-330 esp+ (ECM №- 3408300, code ECM - C20255.05) with C20255.11, but i had next message
    The selected ECM Calibration has been superceded. Superceded calibrations below are grayed out and not available to be transferred to an ECM.The first replacement calibration in the list has been highlighted. Another replacement calibration may be selected from the list. Click the Send to ECM button to transfer the calibration to the ECM.
    but in the list i have only my grayed out calibration.
    incal - feb 2010, insite - 7.3
    where i can find it? or with which calibration i can replace it?
    where i can read in detail about different Calibration Parameters like a FR Option, SC Option, DO Option,PP comments and other? what they arу mean?
  2. #17
    MTCCC
    Guest
    SPAKOS: WOULD U HAPPEN TO KNOW THE CALIBRATION AUTHORIZATION PASSWORD ????
  3. #18
    Quote Originally Posted by zds View Post
    You need to filter your calibrations on insite, right clic on top of the calibrations, select "show active calibrations"
    MTCCC: I think you need to have a "fleet calibration password" tools/options/fleet calibration counts/ADD
    get you PCID and maybe somebody else on the forum can give you a fleet calibration count.
    you need keygen for that
    regards.
  4. #19
    Russia
    Quote Originally Posted by spakos View Post
    i did this. but i got many calibrations for this engine. How to choose what from them is for me? i can't find calibration with all same parameters. and i don't know what's some of parameters meen (e.g. FR Option, SC Option, DO Option,PP comments....)
    can somebody say which calibration (ECM code) most preferable for my engine
  5. #20
    I use the CPL and advertised power. check pics for example
    regards
  6. #21
    Try and use your CPL number up the top wich was CPL 2370 thats the most important one i came up with a lot of Active Calibrations for that Engine. Pick the HP you wont and make sure its an AUTOMOTIVE file not a Machinery file.
  7. #22
    somewhere over there
    Try using a fleet calibration count if you have one
  8. #23
    the problem is you change calibration numer no have on incal cd with this , you need upload differente calibration ,
    prime filter on right click a available calibration
  9. #24
    DK Veteran hercamp's Avatar
    other way is take the calibration with caltermIII or try to get from other ecm ...same if you have and download in boot mode...that can help
  10. #25
    hwo have worked with cummins FASET????
  11. #26
    DK Veteran mondao's Avatar
    Quote Originally Posted by hercamp View Post
    what is this? hercam
  12. #27
  13. #28
    makura's Avatar
    just ignore the mesage and send calibration to the ecm,it will work
  14. #29
    we have a cummins isx 870 motor and cummins insite 7.3 pro, i cannot connect to the ecm, it seems the master,reset and adjustment password has been set by the previous owners. i can view it it read only mode though. could someone please help. thanks in advance
    PCID# 21222984
    expiry date: 29 mar 2011
    functional password: 002-657-c44-75a-bf5-361
  15. #30
    WHEN U RECALLIBRATE AN ECM FOR HORSEPOWER UPGRADE YOU ARE SUPPOSED TO PLUG DIRECTLY INTO THE ECM WITH THE 3 PIN DEUTSCH PLUG I BELIEVE IS WHAT THEY CALL IT AND DO IT FROM THERE IF U DO IT FROM THE PLUG IN THE CAB U CAN HAVE PROBLEMS WITH FAILURES
