Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 64
  1. #16
    thanks so mutch
  2. #17
    Quote Originally Posted by Ne0 View Post
    I have both programmers - Rosfar original, rosfar "blue box" clone and x912tool.de original and "gold box" clone.
    Software from Rosfar ori and clone more stable than soft from x912tool.
    I tested "gold boxed" clone with MB EZS, MB CGW, BMW CAS, CAS2, CAS3 - working fine. but if you click mouse or click keyboard during reading or writing - software momentally halted, and in many cases you need restart pc to run it again. ( it's not problem only with clone - same situation with original hardware from 912tool.de - it's sw problem)
    Rosfar software more stable. But clone work trough usb connection and if you use notebook with "bad" usb ports (ports without sufficient power) or not connect Notebook to AC power - in this case problem's guaranted.
    Original Rosfar, original 912tool and cloned 912tool haven't this problem because use Serial port and external power supply.
    Prompt where to purchase worker "gold boxed" in China
  3. #18
    Eire
    You can try http://www.e-tronic.ehost.pl. They know what they doing. I have 912/9s12 series from them. it can read write without desoldering ofcorse.
    Cheers
  4. #19
    anybody try the smelecom 9s12 programmer sold through fjetech?
  5. #20
    Quote Originally Posted by dbilik View Post
    i have read very much about this two tools and in my opinion red one works without problems.
    the gold one have many problems with the software.
    Better buy the red one. it is more steady.
    i have red case i have make great cas3 XDP512
    but it dont want make me cas3 DG256 0L01Y
    the software go at liking 6 and stop and say me securised !!
    i have install software 9.6 from rosfar
    some one can help me
  6. #21
    Can that gold box clone from x-12(dashcoder) do mercedes vito 9s12 2007- ezs? I can find manual for soldring but not sw for this ezs on x-12 clone.
  7. #22
    DK Veteran stevan's Avatar
    Bosnia
    Quote Originally Posted by yarecky3 View Post
    Cheers
    Yes but only unlocked MCU,here we talking about locked.
  8. #23
  9. #24
    Quote Originally Posted by serka35 View Post
    the software try read go at liking 1 2 3 4 5 6 6 and stop and say me securised !!
  10. #25
    Hello all , since we talk about locked MCU , the programmer use a glitching routine to interrupt the bootstrap sequence of the micro to gain access
    did they have routine for each maskset ? if i have a maskset not present in the list , do you think the programmer will be able to communicate with the processor ?
    sorry to be long , and hope i am clear
  11. #26
    someone that have try this tool on vito 2008- 9s12 ezs?
    There is pdf with soldering point's, can't find vito in software?
    Regards speedofix?
  12. #27
    sunsation..
    freq/power glitch works only on parallell not BDM.
    its kind of SS seek system by bruteforce/reset.
  13. #28
    Quote Originally Posted by Speedofix View Post
    Regards speedofix?
    Sprinter W908, it is the same module...
  14. #29
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by cammy25 View Post
    sunsation..
    How did you know? On paralel mode do not need any thing because the mcu is locked only for bdm access not for parallel reading or writing. For bdm locked processors it is used some glitch on oscillator , and the coax cable it is for that purpose. I put a scope on the rosfar coax cable at work and i see that the frequency is increasing while the programmer try to put the mcu into boot mode.
  15. #30
    Romania
    Quote Originally Posted by motorsport View Post
    For that kind of cas3 you can use xprogm. It works like a charm. For mercedes ezs it is better to use the rosfar clone
