Results 1 to 8 of 8
    Feb 2021
    Default Wow 50012, Laptop w/o internet need help
    I have Wow 50012 installed on the laptop, getting this error when plugging into car (I'v tried using autocom and delphi diagnostic tools)
    Anyone any idea what to do?
    "Important
    Communication to the vehicle could not be established, Please check:
    Is the diagnostic unit correctly connected?
    is the Vehicle EOBD-Compatible?
    Power supply at the diagnostic connector over 12v?
    Is 5 pin in the diagnostic connector assigned (not available on some VW models)?"
    Feb 2019
    Ukraine
    In Wow go to "Settings" then select the "Devices" tab and click "Diagnostic Unit" select your device and com(??). Next, Wow will tell you the rest of the actions ...
    May 2016
    First you must add our SN in file.
    Feb 2021
    Just after getting the wifi fixed on it after like 2 weeks of trying, are you able to help me on teamviewer? Cheers
    Feb 2019
    Ukraine
    Ok, but only on Monday. What is your time zone, I have GMT + 2.
    Feb 2021
    Quote Originally Posted by andrew1061 View Post
    I'm +0 GMT
    Feb 2021
    Quote Originally Posted by el3issa View Post
    hallo , did you fix it or do you still need help
    Hi i still need help, I keep getting error when diagnosing "assembly did not respond" I can remote view with anydesk if you have time to help me, thanks
    Jul 2017
    Please share the link to the version Wow 50012 Multilanguage.
