Results 1 to 14 of 14
    Sep 2019
    Latvia
    Default Peugeot 207, Help
    Hello i have problem with Peugeot 207. Removed egr, but now it shows "risk of filter blocking" on middle screen without any fault codes on engine ecu.
    attached ori, mod and video of masage showing
    BUSCADOS's Avatar
    Rosario
    Can you pass the original DTCs?
    BUSCADOS's Avatar
    Rosario
    so we can make a new file
    Sep 2019
    Latvia
    Sorry i only can do it tomorrow
    BUSCADOS's Avatar
    Rosario
    test and report. Please a thank you and + rate. Thank you
  6. The Following User Says Thank You to BUSCADOS For This Useful Post:
    Smaragds (25th March, 2021)
    Sep 2019
    Latvia
    Quote Originally Posted by BUSCADOS View Post
    The file is identical to my mod file, so i don't think it will do the trick.
    BUSCADOS's Avatar
    Rosario
    and what is not working for you?
    BUSCADOS's Avatar
    Rosario
    without deleting egr, do you have the same legend on the screen?
  10. #9
    BUSCADOS's Avatar
    Rosario
    does dtc have the ori file?
  11. #10
    Sep 2019
    Latvia
    All is working, car runs fine, only that massage showing. And it was showing, yes. Before deleting egr, fault codes was only to egr.
  12. #11
    Sep 2019
    Latvia
    And Peugeot shows that massage when something wrong with DPF, addative or EGR, from my experiance. But this car don't have any faults codes about them, even in addative system.
  13. #12
    BUSCADOS's Avatar
    Rosario
    test pleace and report
  14. #13
    Sep 2019
    Latvia
    So the result was: car needed DPF regen. Its strange that car wasnt showing any fault codes, before and after EGR delete, but in real time data DPF was 58% full, so did DPF regen, and massage on display disapered. Thanks for help Its silly mistake made by me to don't check real time data, and assuming DPF was ok.
  15. The Following User Says Thank You to Smaragds For This Useful Post:
    BUSCADOS (26th March, 2021)
  16. #14
    BUSCADOS's Avatar
    Rosario
    Perfect, it was worth trying, I just ask for a thank you and give me a + on my reputation. Thanks
  17. The Following User Says Thank You to BUSCADOS For This Useful Post:
    Smaragds (10th April, 2021)
