you might have corrupted the eeprom mate, did you mark them before you took em off?
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
need dump micra 56 plate s93c66 please thanx in advance.
soldering from the backside of tacho - or did you remove needles complete to clip eeprom ?
if you removed needles try this:
remove needles again, fit tacho into the car without glass and needles, turn ignition on - start engine - and drive to gas-station an refuel. Then you put needles back - knowing that fuel is max, knowing that temperatur is middle.
... put needles back after refuel - and with engine ON !
i tried to read from back first but did not work than i took eprom off reprogramed chip with new value the new value shows has changed but rave counter stoped working working plus no speedo patrol guage goes all the way to max.
micra tacho needles only able to put in right position - with tacho in car (without cover) - and with engine started, and best with refueld tank.
themp. needle in middle position, (if engine is still worm, otherwise drive 5 minutes)
RPM needle in 700-800 rpm position,
speedo in 0 Km position,
fuel in max position (if full).
then engine off - ignition again on - and you will see:
all is good.
Thanx drkyra but i have done all that i think i have crupted eprom.
Clock sorted Thanx for every ones help here is dump from 56 plate micra s93c66.
