Results 1 to 15 of 17
    Oct 2008
    Default Can ps3 play divx files?
    i was just wondering how to play divx movies through my ps3, does ne1 know?
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Mpeg 4 format is supported
    Aug 2008
    Tamworth UK
    stick em on a disc, put em in the ps3
    Jul 2008
    cmd
    Or use sd or flash stick. Up 2 you my friend,
    Aug 2008
    Tamworth UK
    or stream them from your pc. again up to you
    Aug 2008
    Tamworth UK
    or download them from joox, its still up 2 u
    Oct 2008
    try SD card it will be better.
    Oct 2008
    I use Tversity to stream from my pc ( haven't tried their new version yet ) and it works fine. You can also use a usb memory stick. Window media player can also be used but some poeple find that the video stops playing after about 20 mins.
    Nov 2008
    England
    Quote Originally Posted by kipl20 View Post
    Yeah mate you can there is a code you need to register, with the divx website that you can find on your ps3 first
    Default is there anyway to play divx over wireless network??
    Member Cable Baron's Avatar
    Nov 2008
    if you place your divx files on a pen drive and connect it upto the ps3. then you can go to movies find the usb pen drive and press triangle to view all. you can then watch your movies.
    not sure?
    have you tried
  13. #13
    Oct 2008
    yes there is you need to get a program like TVersity and you can stream the movies to your PS3. if you use a mac like me i use a program called media link which is excellent
  14. #14
    Junior Member davidred5's Avatar
    Thumbs up Try This
    HI there
    I had this problem and found taht some media discs do not work on a PS?, however I have and use USB sticks all the time so I load all of my movies onto this stick and then highlight the USB device in the appropriate menu, hit the triangle button and choose "Display All". You'll see your files then.
    Select the one you want to place (X Button) and hey presto is should be ok as long as the fiel format is recognised.
    If you get stuck let me know I will help wherever I can.
    Hope this helps
  15. #15
    Nov 2008
    Middlesbrough, UK
    i'm using medialink too, works ok apart from the odd errors every now and then.
    might be the fact that im streaming over wireless
