Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Apr 2021
    Quote Originally Posted by davorsule View Post
    I need damos from any of ecu, not exact part number have, from edc15v or edc15p+, vep or vp37 1.9 tdi vag engine.
    I have for example this one but if it is not exact that the ECU you want to remap I think that you waste your time.... I thought that for 1.9 tdi someone damos can work but i now think that it have to be the exact part no. and the sw version... I´m very beginer in Winols and Damos but if someone that reads can explain us a little more...XD!
  2. #17
    Apr 2021
    Quote Originally Posted by chrisimerk View Post
    No that's correct one duration map is smaller then the others this is your main duration map also the duration selector shows 5 maps where you getting the 6th one from ? this map pack is 100% correct
    OOOkkk Sorry Friend! I´m very beginer...! Can you explain me the Diag limiters? Its something new for me and for example I thoug that the diag boost limit value is 620 and Diag mg limit values are about 26000....
    The selector goes from 0 to 5 so i think that have 6 "options" 0 1 2 3 4 5
  3. #18
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by perhas View Post
    Yes it needs to be same sw hw numbers for all maps to match up but this map pack will give you an idea on what maps are what as all edc15p have the same map layout make a map pack for each software version its not difficult
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  4. The Following User Says Thank You to chrisimerk For This Useful Post:
    perhas (4th April, 2021)
  5. #19
    Dec 2019
    Europe
    In file I post in this thread I can't find duration maps..
  6. #20
    Apr 2021
    If ALH engine has rotatory pump and mechanical inyectors... How the ECU can control the injection duration?
  7. #21
    Apr 2021
  8. #22
    Dec 2019
    Europe
    Maybe just with adjusting voltage of electromagnetic valve on rotary pump. I'm not sure how system works, maybe just with pump voltage map.
  9. #23
    Apr 2021
    I had read about never touch the pump voltage maps... Maybe some expert can explain us about this...
  10. #24
    Dec 2019
    Europe
    No, voltage maps must not decalibrate, because they are factory settings for fuel quantity, similat as duration maps. I wrote that this ecu is adjusting fuel quantity by pump voltage maps! But don't know does this edc software have additional duration maps, because I don't know how to calculate eoi and I havent remapped these ecu's before. In this ecu I think duration maps does not exist, but now don't know how to calculate eoi for soi maps correction.
  11. #25
    Dec 2019
    Europe
    Unfortunately, some experts on this forum know how this system works but never will explain to us.
  12. #26
    Dec 2022
    I am searching for DAMOS for the ECU: EDC15p+ 038906019DF-SG 1237 to be loaded to WinOLS. The engine is: 1.9 TDI ATD 101 PS (GOLF 4).
    Could anyone help?
    Thanks.
  13. #27
    qni666's Avatar
    Mar 2019
    Bulgaria
    Quote Originally Posted by mateusz180434 View Post
    Could anyone help?
    Thanks.
    damos for edc15 are u seriosly ?
    NEED PASSWORD ? PRESS THANKS AND ADD REPUTATION
    No files for users who not give feedback or new registred users for free file service like as :
    Okinux,duzaven,1mmortal
  14. #28
    Dec 2020
    I have genuie damos / a2l files for most VAG EDC15.
    Pm me and i will make when i have the time.
