Results 1 to 3 of 3
Thread: how i know ...?
    Nov 2018
    Default how i know ...?
    can i know type vw mqb or normal key or johnsons control by vin number ??
    if i lost all key ..Is there an advantage in the form dashboard that indicates it johnsons control ?
    thanl\k you
    Jun 2013
    With ignition key. Even not programmed.
    You can turn ignition on. If you cut a key.
    Then you need to connect diagnostic tool.
    And read out part number.
    And would probably get the name of the vendor, at the same time.
    Keyless, you need to do some other things.
    Nov 2018
    thank you Weasel3
